[SOLD] Fresh HP 360 Manifold to pan
dusterdoug
Tracy, CA
360 motor for sale. This should be an EASY 11-second pump gas street motor.
74 block and OE crank. Block was jet washed, magged and checked for cracks. Bored to 4.030 and honed with plates. Decked and squared. New Durabond cam bearings. Machined and assembled by a well known Central Valley shop.
OE 3.58 Crank was magged, checked for cracks and straightness, ground .010 under and polished.
New SCAT I beam rods
New KB 107 flat top pistons
Clevite (Coated) rod and main bearings
Hastings file fit moly rings
New OE replacement damper
New timing cover
New EQ magnum heads w/LA intake pattern.
SSI 2.02/1.60 stainless valves
Ported to flow 260 cfm @ .600
Comp 26995 beehive springs
New Comp 1.6 roller rockers
New Comp guide plates
Used Holley Strip Dominator intake
Custom 3310 vacuum secondary Holley. Flows 825 cfm dry. Secondary metering conversion.
Used MP Electronic distributor, great shape
Included also are used 1 5/8” coated Hooker headers.
2 cams to choose from:
New Comp solid flat tappet w/lifters (.554/.564 lift with 1.6 rockers / 244*/252* @ .050 / 110 LSA)
Used Isky Mega hyd flat tappet w/lifters in order (.512/.512 lift w/ 1.6 rockers / 232*/232* @ .050 / 108 LSA)
Asking $4500. It’s located in Tracy, CA. Short block is semi-assembled for inspection. Heads are assembled. Prefer local pick up but would work with a buyer to deliver within a reasonable distance. Could possibly crate and prepare for shipping also.
I would be interested in offers also, without either cam, or the intake if those are not your style. I MIGHT be willing to separate if the short block goes first.
Yea, I know...pics. I'll get some this weekend but I thought I'd test the waters early.
