CudaRay
Hey FABO!
I recently rebuilt my 318, used a Comp Cams 260AH-8 with new comp lifters and springs. After I got the mufflers on it, I noticed a slight ticking around cyl 8/6. With a stethoscope, I can hear some tapping/ticking above the valve cover on cylinder 8, but not below it. It does also increase in noise with RPM, which leads me to believe I have a failing lifter.
When installing, I did my best to make sure there were no ridges on the bores, and I had lube on the lobes and lifters, while also dunking the lifter in oil. I did not, however, realize I was supposed to pump them up with a pushrod before install.
The car has a slight miss or is just rocking a bit more than I'd expect at idle, despite seemingly running fine. I did have cyl 5/7 plug wires get burnt by the headers, but have since taped them up and added heat wrap.
My question is, what all should I be doing before buying a new set of lifters (and camshaft if the cam has started wiping)? I figure checking that pushrod and rocker arm would be an obvious start, but I'm still pretty new to this (first engine build) and just need some advice.
