front bumper fitting
2 fast z28
wisconsin
hay guys im converting my 76 dodge dart to a 72 front clip one issue i see is that the 76 bumper mounted with one large bolt on the side of the frame and the 72 mounts with 2 and they are in different location also so i was just wondering if someone has a qiuck fix or do i have to fab up some bumer brackets thanks
Use a set of 72 brackets. Either weld them on or if you ever want to take them off. I would and have drilled new holes for the brackets you are using then just use bolts with nuts. Did that to my 75 Duster when I changed it to a 71 Demon.
