phish1270
phish1270
I am getting ready to start disassembling the front end on my '65 Barracuda. I am swapping in the '73-'76 disc brake setup and adding an Addco front sway bar. I see all kinds of threads & debates on here regarding where to mount the calipers & which calipers to use. Has anyone done this swap & added a sway bar? I have bought all of the parts that I need except calipers & brake hoses. I plan on mounting the Addco sway bar using their supplied "L" bracket that mounts using the lower shock bolt. Is clearance going to be an issue or is the bar designed to avoid clearance? If I need to go with rear mounted calipers it would appear that late '70s Volare calipers & brake hoses will work. I don't care either way I just want to buy the parts before I take everything apart & limit my down time as summer approaches. My overall goal is to improve handling & be able to stop the car. Thanks for any & all help.
