Front Drum brake troubles on a 1964 Dart
10 minutes of driving and the brakes are wonky… sounds like the shoes are dragging.
When cold how much effort does it take to turn the wheel when it’s jacked off the ground?
It should only have a slight drag when the shoes are adjusted properly and the drums are round .
OP hasn't checked in lately so.....
Yah I know, by now he probably fixed it .
I found it interesting that nobody said anything about adjusting the brakes as the first place to start .
With the OP having a 'professional' mechanic actually working on it, We'd hope adjustment was already adjusted/corrected, but these days......
As far as being 'hub-centric', they are, but I've seen real butcher jobs wafer-wheeling/chiseling/hammering/etc. to remove the swaged stakes. Then They slip the drums over the studs & crank down the wheels over them, but the drums get deformed & may be centered, but they're not square.
I fought and fought and fought aftermarket crap on our '63 9" front drums. They would drag, warp, get hot, go out of round and on and on.. I tried 3 different brands/style of drums and 3 different designs of shoes (yes if you look carefully shoe backing plates are designed differently). I FINALLY got a combo that worked and got in an emergency stopping situation and decided if the wife was driving she could have never pressed on the brake hard enough to stop as fast as I did and put disks on it. I still have the setups that worked on the shelf (with spindles). I am going to Spring Fling in Van Nuys next month and you can have them if you want them.
Thanks! If I was close to so-Cal I'd be totally grabbing those from you. What was the final combo of drum brands and shoes you found that worked?
Thanks,
Paul
Thanks,
Paul
That was too long ago, I wish I could remember but I am sure nothing is the same today as it was 4 years ago.
Later 9 in drums are finned. I think they started in 70. Heavier and I would think less likely to warp. I put a set on my 64 and they work fine (for 9 in drums anyways). You can also use 67 or newer shoes and adjusters but have to get a matching set, the shoes have the posts for the adjusters where shoes for early cars are identical but missing the studs. The newer style is more reliable.
The Chrys 9" drum adjusters are so simple in design & very few parts, yet so reliable in operation that I adapted them to use on my GTO that has 9.5" drum brakes.
A buddy of mine went through a similar problem with the 11 inch drum brakes on his GTX. What he found was the same as some others have said, new drums out of round but with a twist. He also found that the new shoes were only touching at the very top of the front shoe and very bottom of the back shoe. So he took the long strips of sandpaper with the glue on the back for body sanding boards and lined the brake drums, spun them as he tightened the adjusters till he got an even wear pattern on both shoes and this fixed the rest of the problem of the brakes getting hot. Turns out that the taper that brake shoes use to have at the top and bottom of the friction material is either not there or not enough for full contact on the new junk shoes that are being sold.
