front end bushing kit needed help me out please
chubsgts
mi
so i got a littel further in then i thought when i started seeing dry rotted bushing i said ok time for it to go
so i need all the bushings like
torsion bar dust boots
lower control arm bushings i think they call it for the shaft that goes thru the k frame and into the lower control arm and torsion bar pushes against it
strut rod bushings
sway bar bushings
i think thats all of them down there
all of my front end is rebuilt like ball joints tie rod ends now i just need the bushings
i would like a rubber kit vs a poly kit i had problems with poly before
does any one know if theirs one out or if all i can get is poly thats ok two
i had a problem with them making noise i was told they need to be regressed like every year is poly the same as the hyperflex or Polygraphite
kit numbers and links would be great i looked but didnt find much
thanks
I was just going to post a similar question......
I am in need of re-doing my front end and I have heard that poly will give you better handling than rubber. What are some of the problems with going poly?
By the way I want to just redo everything up front. its never being done on the car and I just think that it deserves the full treatment.
