[SOLD] Front/Rear set of black door panels
4spdragtop
Ontario Parts Unknown
Hi all, here are used fronts/rears. Front panels are from Dads 67 cuda. We put new Legendary in. The rears I think are 67-69 cudas, but no holes for arm rests?? Maybe someone can clarify. Fronts are definitely usable, Dad epoxied a repair on the back of one board. See pics. Rears are in nicer shape, there is a repair on the back of one, but its solid....(see pic) I figure $50 plus the ride..These will ship in the Legendary box Dads new panels came in. What clips I have here, you can have.
Shipping from Ontario
Thanks
Steve
I don't see a pic of the rears. They are all different though. Shape differs for fastback and notchback. Temp pleat pattern changes for every year model.
If I ever did get around to building a custom center console I would need that door panel material to skirt it. I don't have funds today so.... Good luck
Here are rear panel pics. You can see repair in last pic. Its solid and I believe the repaired spot once installed would be beside rear seat, somewhat hidden.
Rear armrests were an option. My fastback doesn't have them.
They are not 67-9 dart or valiant. The pattern looks like 68-9 cuda
Thanks! I know the fronts are 67 Cuda with deluxe interior. Just wasnt sure what the rears were. Weird how arm rests were optional back then, but ashtrays and cigarette lighters are now....spare tires too...LOL Oh ya, bump still for sale.
Definitely a fastback shaped rear panel. It would fall short of covering a notch.
Even more issue with misfit, the window winder holes are in different locations.
69 Barracuda Fastback passenger side for comparison. Looks the same to me, no armrest only window crank.
Yep my 67 slant sux strippo notchback came without rear armrests. I am hoping when i purchase new ones the only hole punched will be for a window crank. Yes the fronts are for a 67 with standard interior. The rear ones patterns are for 68/69.
The deluxe interior door panels for 67 would have had a woodgrained insert, and heat embossed chrome plastic trimming it off, i believe a red reflector at the rear of the panel at the woodgrained trim as well.
If the rear panels were from a 67 notch i would have been interested. They are in good shape for 40 plus year old parts the wrinkles will be hidden by the rear seat anyways. The repair to the fiberboard looks well done. I have repaired these with fiberglass this way in the past.
You should have no problem selling these. As i said if they were the correct year and body i would have wanted them
Good luck on your sale
Matt
