front strut rod using pst bushings question
trbodrt
so. cal
72 dart with slant 6 k member, I'm putting my front suspension together using pst polygraphite bushings. the strut rod where it bolts to the k member has a hole for a cotter pin, It seems like the bushings won't compress enough to get past the hole, i'm using the two piece bushing with a sleeve and a washer on each end. it this normal, should i just use some loctite, or is something wrong.
