Okay guys, Afew suggestions needed here. I'm gonna atempt the swap to the '73 front suspension. can this be done fairly easy with the motor in the car (k-member also) ? and where to start first? ANY INPUT WILL BE APPRECIATED
If you use jack stands to hold the car up and either block the oil pan up for the engine, or use a hoist to hold it up, it should work fine. Start by backing the T-bars off, remove them, undo the upper control arm bushings and shocks, brake lines, strut rod nuts and bushings, engine mounts, steering box, and finally the K-frame bolts and whala ( how do you spell that? ) the hole suspension should fall out. Oh, sway bar if you have it.
