pacuda59
pacuda59
I picked up an 8 1/4 rear from a junkyard this weekend. I've gotten the drum off of one side but after an hour of working the other with a hammer and chisel it remains frozen. Any suggestions or tricks?
Have you drenched it with penetrating lube of your choice?I picked up an 8 1/4 rear from a junkyard this weekend. I've gotten the drum off of one side but after an hour of working the other with a hammer and chisel it remains frozen. Any suggestions or tricks?
There is an emergency cable hanging off the back. Not sure what the spring nails look like. This is my first go round with drums.
I guess a Sawzall should work.
Small sharp metal chisel and a hammer. Cut the heads off the pins.
