Lars
I've been trying to get my 70 together. I got the engine back from the machinist back in November. Cost more then it should have, and took two weeks longer then I expected. Tried to assemble the engine. Ran into an oil pump clearance problem with the ARP bolts, a week later, got a new bolt from ARP, and it fit. Then all my timing cover bolts manage to disappear, spent two days getting that straighted out. Then the intake bolts wouldn't fit, had to ham fist something together to get the intake on. Went back later and was able to put some better fitting bolts in. Then my MP black wrinkle valve covers wouldn't fit, ground on one to try and get it to fit, but still would fit right, had to reuse the grimy nasty chrome valve covers (that I hate) back on it.
Then today I tried to stab the engine, turns out the driver's side mount is different on a 70 318 then it is on a 72 360. This isn't the width problem, there aren't enough mounting holes to bolt the bracket on the engine. So I had to order a driver's side mount, which I couldn't really afford, but I don't have a choice. The biggest problem is it'll be late next week before I get it at best. I was hoping to fire the engine on the 26th as I'm extremely paranoid that all the cam break in fluid is going to drip off the cam and it'll wipe a lobe. Plus I somehow managed to chip my new paint in the engine bay while I was trying to get it in. Now because of this mount problem I probably won't get the engine stabbed until next year. For such a simple swap this has been extremely frustrating.
On top of the fact that I've been trying to get the car together while working 60-70 hours a week, and as we get closer towards the end of the year they are only going to want me to work more and more hours. I'm almost afraid to go and try to do anything else at this point because of what might go wrong next.
I went through about the same problems...."only way more" when I did my first plymouth re-build. I must have had the engine out about five times by the time I got the dam thing to work correctly. One thing however, I didn't know about this forum to help me out. Take your time and ask mega questions and it will all work out. I do feel your pain!! with those little things THAT BITE :angry4:
