FS +7 cc Venolia 340 forged pistons stock bore
Schweppes
Active Member
Portland Oregon
Hi Fabo, Im selling +7 cc venolia forged pistons for 340 4.04 bore. They have super light tool steel piston pins and total AP seal rings. They are used slightly with dyno pulls on them. Im asking $225 for the set. Im located in Long Island NY.
I also have a supercharged 340 for sale. I changed direction and am going with a Ernie Elliot R5 instead. The 340 had all the machine work done, its complete and ready for assembly. The 340 is .020 over and stock stroke
Comes with:
-Ported and rebuilt W2 heads with new manley savere service s/s valves, new spings and retainers, mopar W2 offset rockers everything new.
-Holley strip dominator manifold matched to heads
-hardned pushrods
-fabricated valve covers
-Custom Wiseco pistons 8.7 compression reverse dome
-venolia rods
-kellogg 8 bolt crank (reciept assm has been balanced)
-schnieder 296 custom grind cam for blower, 575 lift, solid, 112 lobe center
-cloyes billet timing set
-melling oil pump
-mildon oil pan with pick up
-gasket set
-brad penn break in oil
-block has huges gridle installed the #2 way with machined main caps
-block was decked, aligned honed with arp studs and girdle installed
-bored .020 over with torque plate, $2000 spent at machione shop alone have the reciept
-tci rattler damper
-Paxton Novi 2000 supercharger, with 3" cog belt supports 900 hp
All the motor parts are new, let me know if anyone has insterest
Heres pic of the venolia pistons.
First $100 + shipping takes em, moving do not need to pack with me. Stock bore 340. These are light and strong, no junk here!
