Fuel Air Mixture?
Dan408stroker
Halifax
I am thinking about welding in a couple of taps and installing a dual channel fuel/air mixture sensor set up like the FAST system. Does anyone have any experience with these things? Which is best/best value?
Thanks
Dan,
Se my recent post on AFR meter..
Runnig two AFR sensors would be both cost inefficient and unnecesary, assuming your engine and intake (fuel distributuin) is in reasonably good shape, the readings from one header or manifold side should be representative. Alternatively, you could of course weld in a bung on each side and simply swap the sensor over for comparison/ verification.
If you go to e-bay, you can find a complete sensor-driver-gauge package from innovate as low as arround 170$, and in my mind, that's a great price and fantastic value for money considering what this will do for you!
Leave all doubts behind and order one today, you'll never look back!! :)
