Tryin to figure out my non working fuel gauge. Hooked ground up at sending unit and gauge moved. Added ground to sending unit because it was missing. Still nothing. Today I had the cluster out and noticed when the cluster wasn’t grounded to the dash with the head light switch on the fuel gauge would work. But as soon as I install the cluster to dash it doesn’t. What could be causing that?
