MoparBrit
HillingdonDart
Okay, considering putting in an aftermarket fuel level gauge. Stock one works when it wants too. Temp and everything else works okay all the time, but fuel sometimes works and sometimes does not.
I am going to ground the lead and see if it isn't just a factory sender problem, but the thought came to me that I might add a three gauge panel and put a fuel level gauge in it.
So, my question. I tried to look up on the net what the ohm reading should be for the sender. Found a place that listed Chrysler at 0 - 2 ohm empty and 70 to 73 ohm full.
Well, go to look at gauges and I find some Ford/Mopar ones that are saying that Mopar should be about 73 ohm empty and 10 -13 ohm full. Different reading and opposite.
Can someone confirm what is supposed to be correct for a '71 Dart?
Also, has anyone run one of these 73 ohm empty and 10 ohm or so full gauges on their car? How accurate is it?
Thanks for any help.
Cheers
Cheers
