JGC403
I have a mild build 383 with manual transmission and QFI's Fuel Injection System. I got it running and now I'm trying to dial in the VE Table. I have the Adaptive Learning OFF and I'm trying to tune the VE Table RICH (12.8:1) so that when the adaptive learning is ON the PCM will pull fuel from the table and the target A/F ratios right now are: Idle 13.5; Cruise 13.8; and WOT 12.7
I'm slowly tuning the VE table. I take it for a ride record the screen, go home watch video and increase the VE table where it was lean. Sometimes when I am driving and I let off the throttle the rpm doesn't drop down quickly, it will hang up around 1500rpm for a little, or when I press in the clutch and let off the throttle to shift the RPM hangs up there it doesn't drop like it should. Anyone know why it would do this? Throttle should be snappy, go down almost as quick as it went up.
