fuel line to carb question
texas360
TEXAS
i am trying to get rid of my rubber fuel line and go back to a steel line... what size and type
adapter would i need to hook this line to my Edelbrock carburetor.. Summit guy was no help... can i get it at any parts store or home depot maybe.
Right Stuff Detailing Fuel Pump to Carburetor Lines RPC6806
Hmmmm, you’re gonna need to provide a few more details.
Without details, how about going 1” and getting it at Pep Boys?
So what year and engine does your car have now? What carb does your car have now? What is the size of the metal line that your car has now? Or is it rubber all the way back to the gas tank?
this is on a 73 318.. i bought The Right Stuff brand steel line in link above to replace my rubber line from the fuel pump to the carb... the hard line will screw right onto my stock fuel pump, but it needs some kind of adapter to screw into side of my edelbrock 1405
i found these pics online.. this is what im needing.. the brass fitting,,,
If you have a barb fitting that screws directly into the carb body (I have never seen one), then you need to rob the proper fitting off a junk carb.
As others have suggested, consider bending the line yourself. I did that with mine and, although it took a couple of tries, it’s satisfying looking at it every time I open the hood and see it.
I had a spare 4 bbl carb around that had that correct threaded fitting that I needed. I would think Edelbrock would sell those. Otherwise ebay under carb rebuild kits.
Just like this:
thanks guys.. i actually got lucky and found fitting on an old carter carb i had for parts ... got it together to made it to a show Saturday
