Cuda Al
Put the new push rod in, coat in assembly lube. Don't chase your tail till you know there is still a problem.
My car was doing exactly the same thing, vapor lock like symptoms (fuel starvation), will cause car to run hot.
If your gas gauge is working then only replace the sock.
Alan
Alan
