After a long break, I'm back on tuning my Duster. Figure it's getting too much fuel (stock carb settings), and when I pulled the carb this morning there was gas laying in the bottom of the Air Gap on the driver's side. 360, Holley blue pump set at 5.5 psi (according to both gauges I've used); Carter 750, floats set at 7/16 & 15/16, New needle/seat assemblies. Pulled the top, zero junk in the bowls. I had this problem before with this carb, ended up being the secondary booster gaskets. Primaries were wet this morning (could have been from when I removed the carb though), any other things to look for before I replace the gaskets and reassemble?
