When I bought my duster it had a Tanks Inc. tank and pump, so I don't have the specifics of the pump. it's ran to a holley 12-841 pressure regulator (with return), and then to an edelbrock 750 CFM carb on a 360 magnum engine.
The car had been running really well with no carb issues. I got it out a couple days ago, and it started developing an issue where it would die or bog badly every time I hit the gas and I could smell raw fuel. It would fire right back up, and I would have to get the RPM's up in order to overcome the hesitation.
I'm under the hood checking everything out and I notice that the gauge on the regulator says it's at 9 pounds. Seems a little high, so I do some googling, find out that edelbrock recommends 5.5, so I adjust it down, and BOOM .... hesitation is gone, and the cars idling better too. I continue to let the car run for a few more minutes, and within 5 minutes it's right back to 9 pounds again. I don't think it's an issue with my return line being too small, I'm running 3/8" fuel line.
So I'm trying to decide what my best option here is. I've read reviews on the holley 12-841, and it seems a few people have issues with them and can't get them to adjust.
Should I buy a rebuild kit and see if that fixes the issue or should I just invest in a better pressure regulator that can handle more pressure? Does anyone have any ideas on what the cause could be? I've always had a mechanical fuel pump on my mopars so I'm not sure what my best course of action would be.
