Fuel sender issue
Fuel and Air Systems
  1. hoosierdaddy
    hoosierdaddy FABO Gold Member FABO Gold Member
    438
    195
    Nov 13, 2008
    Central Indiana
    Local Time:
    4:43 PM
    I installed a Tanks Inc tank with in tank E fuel pump in my 72 Duster . I have an odd problem , when I set sender and fuel pump in I tied the grounds together thinking this would work fine . My fuel pump works fine but I'm not getting signal to my fuel gauge so after checking the cluster and finding nothing obvious I turn to the sender . I had my wife sit in the car and turn the key on while probed around with a temporary ground and my gauge started working . The tank is in the car and I'm working pretty much blind so I can't see what I was touching with the temporary ground but I figured there must be an issue with the ground being tied into the fuel pump ( I know makes no sense) . So I install a dedicated ground for the sender and I get zero reading again . Any thoughts ?
  2. RPMagoo
    RPMagoo Just An Old Motorhead
    2,802
    1273
    Nov 4, 2015
    N.E. Pa.
    Local Time:
    3:43 PM
    -- :popcorn: -- I'm having a similar problem. My pump is not in the tank, but I believe that I have a ground problem. -- I have a new tank, and sending unit, and a new, summit, fuel gage. All have the same OHMs range.
  3. superchargeddrt
    superchargeddrt Well-Known Member
    2,157
    706
    Aug 24, 2009
    Pittsburgh, Pa.
    Local Time:
    4:43 PM
    The sender works on a ground. If you accidentally grounded the sender wire with your "temporary" ground then your gauge would read full scale. This is how I check my fuel gauge by grounding the fuel sender wire. I would suspect that either there is s bad connection at the sending unit or a bad sending unit.
  4. hoosierdaddy
    438
    195
    Nov 13, 2008
    Central Indiana
    Local Time:
    4:43 PM
    When I used the temporary ground my gauge read just above 1/2 tank , never did go to full .
  5. Frnknsteen
    Frnknsteen FABO Gold Member FABO Gold Member
    548
    333
    May 26, 2011
    Spencer, IN
    Local Time:
    4:43 PM
    Gauge bad maybe? Or maybe some resistance in the wire leading up to your instrument cluster?
    • Agree Agree x 1
    • halifaxhops
      halifaxhops It's going to get stupid around here! FABO Gold Member
      52,034
      20122
      Jan 20, 2014
      CENTRURAL, PA
      Local Time:
      4:43 PM
      You have the ground clip to the metal fuel line?
      • Agree Agree x 1
      • RedFish
        RedFish Well-Known Member
        23,426
        2243
        Sep 5, 2007
        Local Time:
        3:43 PM
        A sender with 2 wires, signal and ground, wouldn't require the OEM chassis ground jumper on the fuel line. If your probing around had grounded the signal wire a good gauge would have went to max full position.
        What we don't know... Ohms range of your aftermarket sender ( should be 80=E / 10=F ),
        Tanks capacity and how much fuel is in it.
        Keep in mind that most aftermarket senders are linear. They'll send approx' 45 at 1/2. The OEM thermal gauge looks for 23 to get 1/2. To get the OEM gauge anywhere near accurate throughout the range you will need meter match module.
        • Agree Agree x 1
        • hoosierdaddy
          438
          195
          Nov 13, 2008
          Central Indiana
          Local Time:
          4:43 PM
          I don't have metal fuel lines my car is set up with -6 fuel hose
        • superchargeddrt
          2,157
          706
          Aug 24, 2009
          Pittsburgh, Pa.
          Local Time:
          4:43 PM
          The sending unit has a metal nipple coming off of it for the fuel line. If you don't have a factory ground clip the use a small hose clamp to attach a ground wire. Ground it to the frame.
          • Thanks! Thanks! x 1
          • Agree Agree x 1
          • hoosierdaddy
            438
            195
            Nov 13, 2008
            Central Indiana
            Local Time:
            4:43 PM
            There is no fuel line coming from this sender it's an aftermarket sender from Tanks Inc . I have an electric in tank fuel pump .
          • 64mopar
            64mopar Well-Known Member
            56
            28
            Apr 14, 2019
            The Burgh
            Local Time:
            4:43 PM
            If you can get to the wires going to the sender, ground the supply feed wire to a good known ground or run a wire from the negative battery to it, if the gauge goes to full it is a sender or ground issue.
            If it does not, it is a gauge issue.
            If the gauge goes to full take the ground wire and send it straight to the battery, if the gauge matches the amount of fuel you have in it, it is a grounding issue.
          • superchargeddrt
            2,157
            706
            Aug 24, 2009
            Pittsburgh, Pa.
            Local Time:
            4:43 PM
            Run an a wire connected to an eyelet terminal and connect it to one of the sending unit mounting screws. Should have realized the situation,I have the tanks Inc system as well but didn't have the issues you're having.
