Fuel system advice
Discussion in 'Magnum Engine Swaps' started by haybag, Apr 2, 2018.
  1. haybag
    haybag Well-Known Member
    159
    11
    Dec 14, 2014
    New Hampshire
    Local Time:
    2:02 PM
    I am getting to the point in my swap where i need to start thinking about the fuel system. I am using a 95 5.9, OBD1 ,keeping the injection. This engine does not have the return line or regulator on the rail. I am planning on buying an EFI tank and pump from Tanks Inc. Would my best bet be finding an earlier fuel rail with the regulator and return or buying one such as the corvette style reg with a return, appreciate your advice.
  2. 72demon
    72demon Well-Known Member
    186
    10
    Feb 4, 2008
    Mishawaka IN
    View My Photos
    Local Time:
    1:02 PM
    Junk Yard
  3. dusterMike
    dusterMike Member
    21
    1
    Feb 5, 2012
    martinsburg, WV
    Local Time:
    2:02 PM
    I would add an external fuel pressure regulator near the tanks inc tank, then run a short fuel return line back to the tank. with that set up you should not have to mess with the fuel rails.
    • Like Like x 1
    • Revhendo
      Revhendo Hornet Hammer
      10,272
      10832
      Mar 12, 2006
      SoCal
      View My Photos
      Local Time:
      11:02 AM
      I'll be installing full length pressure and return lines to an Aeromotive bypass fuel regulator by the engine in mine. I know how I am and want to have my options open when I decide that the stock Magnum isn't enough.
      • Like Like x 1
      • Agree Agree x 1
      • mopar65
        mopar65 Well-Known Member
        1,581
        1390
        Mar 23, 2008
        Laquey MO
        Local Time:
        1:02 PM
        I got this info from AndyF. He is installing a fuel injected big block in his white Duster. He made a post about it in the big block Abody section. But Looks like Holley is making a fuel pressure regulator/ fuel filter set up now. I don’t know if it’s something you might be intrested in but might be worth a look?
        https://www.jegs.com/InstallationInstructions/500/510/510-12-875.pdf
        • Like Like x 1
        • robcuda
          robcuda FABO Gold Member FABO Gold Member
          129
          26
          Oct 18, 2016
          Albuquerque
          Local Time:
          12:02 PM
          I agree with dustermike, I will be ordering parts for this same set up soon and if you are keeping the magnum stock I believe you will want approx 48 psi +/- 2 psi The corvette regulator as far as I can tell is a non adjustable 58 psi. Tanks Inc, sells a adjustable regulator for approx $85.00, it will allow you to reduce to the correct pressure and add a short return line back to the tanks inc tank. You can also get a 20 micron filter from tanks inc too.
        • famous bob
          famous bob mopar misfit
          11,013
          2668
          Aug 14, 2011
          okla
          Local Time:
          1:02 PM
          fast, jegs, summit , all have that type regulator, it came w/ my fast 2.0 kit.
          • Like Like x 1
