hi there, try this method.... go around the car,:clock: make a list of what electricals are on there and more importantly what is working, ie lights,back up lights,horn, radio,interior lights,cigar,trunk light etc etc......:read2:then pull #1 fuse and see what stops working, :cheers:make a note, replace and move onto #2 fuse.reason to check whats working prior to removing as some stuff may simply not be working,ie bulb out/broken wire and you end up chasing your tail. its mundane but we used to do it on mains voltage houses shops when we had a unmarked fuseboard there.
