If it was reeealy short, it could effect the thermal effects in the wire; the connecting lugs could remove or add heat to the wire. I would suspect that once you get to 6" or 8" or longer, it would not have enough effect to make much difference.
The above would be of concern for mild overlaods. A hard short should take it out regardless of length.
