StickweldinSteve
Thanks for the advice, I’m probably going to end up replacing the tank too. It looks rough.Everyone can do it how they like and I don't condone this to anybody but I've put front floor pans in my Valiant with the gas tank in I put lower quarters on the Valiant with the gas tank in I patch welded the trunk floor at the seam where the windshield leaked and rusted through ...with the tank in. You probably need a couple things going on... like fuel Vapors... so your tank needs a leak or lines must leak in or around the sender for that... non ventilated work space to act as a vapor ballon... maybe ground to the tank and itself...or you need to use a torch so you can burn a hole through the floor and through the gas tank to achieve blowing yourself up. Good luck! Lol
