Gas tank filler tube removal
strange screws
tamper proofs so no one snakes the quick filler. cut a slot or drill out and replace. or find that bit. Eaton made them for Mopar for radios too
Yep, tape up the tank opening real good and Mototool a slot in those puppies
I ended up taking a small flat tip screw driver and was able to turn them till I could get vise grips on them , anyway got the old gas tank out and now getting ready to insyall new one and clean filler tube
I use needle nose vise grips to back them out a few turns from inside the trunk area. Then I can grab the head outside. Reverse procedure to tighten them back in again. Others are easier than fastback of course.
