Went to go riding around Saturday. Started my '73 Duster 340, it ran about a minute and run out of gas. I know there was about a quarter tank, but the gas gauge doesn't work right so I went and got some gas. When I took the gas cap off, there was a vacuum. Once the gas got to the carburetor it started right up. I drove it around for a while before stopping to fill up. There was no vacuum this time. Saturday was the first time I noticed this. Is there supposed to be a vacuum or is there a vent I need to find?
For a stock, unmodified system, the 1973 A-bodies employed both a fuel tank vent line and a pressure/vacuum fuel filler cap.
A single vent tube at the upper center front of the tank connects via a rubber hose to a metal tube that runs to the front right corner of the engine compartment. An overfill limiting check valve is formed within the end of the tube there. This end of the tube connects to the charcoal canister as part of the evaporative emission capture system.
The vent tube is the primary vent for the system. However, the fuel cap contains a pressure/vacuum vent in the event of significant over pressure or vacuum conditions.
If the vent tube is blocked and the fuel cap vent valve fails or incorrect cap is used, high pressure or vacuum can be held in the tank. If the vent fails, but the cap is good, mild pressure or vacuum may be present.
For failure to vent in a stock 1973 A-body system, check the following:
- Sticking or blocked overfill limit check valve
- Canister hose to metal tube for blockage or collapse
- Blocked canister
- Vent tube connector hose at the tank for blockage or collapse
- Metal vent line itself blockage due to clogging or damage
- Internal tank vent tube blockage
- Fuel cap pressure/vacuum valve. This should still relief vent if the canister/tube/valve is blocked and pressure or vacuum gets high enough unless it is also bad.
The check valve end on the metal tube at the charcoal canister can be replaced. Original part is # 3642263. See the factory service manuals for replacement procedure.
Original 1973 pressure/vacuum cap on my Duster:
Overfill limit check valve end of vent tube:
Charcoal canister vent tube connection:
