Gauge pods anybody
i just screwed them into the upper dash pad on the lower side infront of the gauges that they took over for
[ame="http://www.youtube.com/watch?v=pviXVh2Uaq0"]http://www.youtube.com/watch?v=pviXVh2Uaq0[/ame]
Fishy,
I have entered into a relationship with the owner of what used to be Cyberdyne and Nordskog to produce two digital products for each MoPar style as the interest goes.
First I sent him a complete gauge cluster from my 73 duster. He is taking that and removing the gauges from the back and designing a circuit board that you can bolt to the back of a stock gauge cluster. Because of that the amount of information will be limited to the available openings in the stock cluster.
Then, I am in the process of getting a pristine gauge cluster which I will cut the back out of and flat back it to create a mold for carbon fiber inserts that will fit into the stock opening. The CAD drawing shows the amount of gauging I can fit into a enclosure for the factory opening in the dash.
Andrew
Fishy,
Andrew
Interesting. Please keep us posted, Andrew!
Fishy,
Andrew
Excellent! Sounds like it should be real cool. You make me wish I would have waited to restore my dash. At the time I did it last year nobody was making anything aftermarket for them and it didn't look like anyone was.
I talked to Just Dashes last year about doing this very thing --adding 2 gauge pods to my a-pillar. They quoted me a price roughly equal to one of their dash pads with the gauge pods built in. Ridiculously expensive!
Jeez!! some companies are bad about that. I have a few projects on the burner and will probably get back on this in a month or 2. I think I've decided to make my own using plastic pvc pipe cut at the right angle and epoxied to the A-pillar trim and finishing it with carbon fiber.
