DartGTDan
'71 Dart GT Fan
My buddy has a '65 A100 pick up truck. He's found a liquid on the passenger rear wheel after sitting all winter. He's not sure if it's brake fluid leaking from the wheel cylinder or if it's gear oil leaking from the axle seal.
How do we tell which liquid it is? I'm thinking if it was brake fluid the paint, on the painted steel wheel, would have been damaged (after sitting for 5 months). He simply wiped it away with no visible paint damage.
I thought maybe try smelling the liquid. Gear lube is pretty pungent vs. brake fluid.
Any ideas, suggestions?
