Jan 7, 2020 #1 72Dart6pack Harder Better Faster Stronger. Joined Feb 1, 2016 Messages 5,196 Reaction score 6,407 Location Michigan Is there a direction this roll pin removes on the gear selector. Automatic car. Column shift 1972 Dart. I don't wanna break anything. What size center punch should I be looking for? Thanks
Jan 7, 2020 #2 Alaskan_TA Well-Known Member Joined Nov 12, 2004 Messages 6,414 Reaction score 5,314 Location PA See the recent thread here at INFO PLS... how to remove pin from column shifter?
Jan 7, 2020 #3 72Dart6pack Harder Better Faster Stronger. Joined Feb 1, 2016 Messages 5,196 Reaction score 6,407 Location Michigan That's perfect. Thank you.
Jan 7, 2020 #4 Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 19,349 Reaction score 16,710 Location Northern Colorado Make sure you get a roll pin center punch, cheap on e-bay.
Jan 11, 2020 #5 72Dart6pack Harder Better Faster Stronger. Joined Feb 1, 2016 Messages 5,196 Reaction score 6,407 Location Michigan 3 nights and a rat tail file. It finally came out. No damage to the collar. Off to go get a beer.
Jan 11, 2020 #6 Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 19,349 Reaction score 16,710 Location Northern Colorado FYI, a roll pin punch has a dimple to keep it centered. These work way easier than standard punched
Jan 11, 2020 #7 72Dart6pack Harder Better Faster Stronger. Joined Feb 1, 2016 Messages 5,196 Reaction score 6,407 Location Michigan This pin was not coming out with a punch without breaking the collar. Rat tail file and a couple cups of coffee. Problem solved. ✌
