72Dart6pack Harder Better Faster Stronger. Joined Feb 1, 2016 Messages 5,172 Reaction score 6,349 Location Michigan Jan 7, 2020 #1 Is there a direction this roll pin removes on the gear selector. Automatic car. Column shift 1972 Dart. I don't wanna break anything. What size center punch should I be looking for? Thanks
Alaskan_TA Well-Known Member Joined Nov 12, 2004 Messages 6,415 Reaction score 5,289 Location PA Jan 7, 2020 #2 See the recent thread here at INFO PLS... how to remove pin from column shifter?
72Dart6pack Harder Better Faster Stronger. Joined Feb 1, 2016 Messages 5,172 Reaction score 6,349 Location Michigan Jan 7, 2020 #3 That's perfect. Thank you.
Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 14,938 Reaction score 12,300 Location Northern Colorado Jan 7, 2020 #4 Make sure you get a roll pin center punch, cheap on e-bay.
72Dart6pack Harder Better Faster Stronger. Joined Feb 1, 2016 Messages 5,172 Reaction score 6,349 Location Michigan Jan 11, 2020 #5 3 nights and a rat tail file. It finally came out. No damage to the collar. Off to go get a beer.
Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 14,938 Reaction score 12,300 Location Northern Colorado Jan 11, 2020 #6 FYI, a roll pin punch has a dimple to keep it centered. These work way easier than standard punched
72Dart6pack Harder Better Faster Stronger. Joined Feb 1, 2016 Messages 5,172 Reaction score 6,349 Location Michigan Jan 11, 2020 #7 This pin was not coming out with a punch without breaking the collar. Rat tail file and a couple cups of coffee. Problem solved. ✌
