May 31, 2024 #1 63SplitWindow Well-Known Member Joined Nov 21, 2021 Messages 319 Reaction score 190 Location Montgomery County PA When buying a gear set for an 8.75 chunk do I need to specify which case?. Like 742 or 489? Are they all the same? Thanks
May 31, 2024 #2 mbaird mbaird FABO Gold Member Joined Dec 10, 2005 Messages 11,083 Reaction score 8,369 Location Boise, Id Yes
May 31, 2024 #3 mbaird mbaird FABO Gold Member Joined Dec 10, 2005 Messages 11,083 Reaction score 8,369 Location Boise, Id Different pinion diameters and taper
May 31, 2024 #4 63SplitWindow Well-Known Member Joined Nov 21, 2021 Messages 319 Reaction score 190 Location Montgomery County PA Glad I asked Thanks
May 31, 2024 #5 63SplitWindow Well-Known Member Joined Nov 21, 2021 Messages 319 Reaction score 190 Location Montgomery County PA One more question: I want to change my gears on my spool rear. Anything I need to know about the differences with a spool? I have never did one before Thanks
Jun 1, 2024 #6 mbaird mbaird FABO Gold Member Joined Dec 10, 2005 Messages 11,083 Reaction score 8,369 Location Boise, Id I have a spool and a set of 4.30s but haven’t set them up yet . I can’t imagine there would be much difference.
Jun 1, 2024 #7 RustyRatRod Caput villa stultus FABO Gold Member Joined Jun 7, 2010 Messages 121,794 Reaction score 133,019 Location Georgia Need to specify. They are not all the same.
Jun 1, 2024 #8 mderoy340 Well-Known Member Joined Aug 2, 2012 Messages 2,797 Reaction score 1,780 Location Melbourne FL Spools use the larger diameter 2.0 carrier bearings. If you are buying a full bearing kit make sure to specify the larger diameter.
Jun 1, 2024 #9 63SplitWindow Well-Known Member Joined Nov 21, 2021 Messages 319 Reaction score 190 Location Montgomery County PA Ok. Sounds like I need to open it up and inspect things before I order the parts I guess. Thanks guys
