bdusted440
If I’m hitting 6200 RPM which is my red line 200 to 300 feet before the trap with a set of 430 gears 275 6015 drag radials what should I step down to like 410s?
Won’t fit. This is big as I can goPut a little taller tire on it.
Not sure I went to Midwest converters and they gave them all the specs of my motor trans and rear end in car and they build me a converter . supposed to be a 3000 stall that’s about where it stalls at.If it's auto, what is your convertor slippage? You should be able to calculate it.
Thanks4.10 should be dead nuts.
