gen3 hemi question
As far as I knew that was old technology before formed flex plates when all you could get was a flat plate and it needed to be spaced out for converter clearance. I don't run one. No need to.
Hemi Joes right, old tech... I have the flex plate for the swap, no spacer needed...
Joe
A&A Transmission sell one , pn AA753 , $85 in there 2010 Catalog , looks the same as ATI's .
For me the convertor to flex plate bolts line up perfect , I'm using a 904 .
I think you will already know this , There is one offset hole . so it will only fit when the offset is matched between the two parts .
