In the mad electric diagrams, couldn't you just take the black wire that goes from the welded splice to the alternator, and run it to the starter relay with a fusible link on the end of it.
Then take a new wire and run it from the alternator to the starter relay, with a new fusible link.
Then take the black wire that went from the welded splice to the ammeter and get ride of it, along with the red wire from the ammeter.
I don't understand why they keep the red/black wires and splice them together.
They are already cutting into the harness, so why not make it less complicated.
I have a new harness so I want to keep it simple, will what I laid out work?
I also have an ammeter in a 3 gauge pod under the dash, and I might just run the wires there. Thoughts?
