The rate at which the timing comes in on a stock engine is pretty slow and is not optimal for performance. This is done because the manufacturers have to protect the engine against drivers that don't use the correct fuel, lug the engine, etc.
The overall performance is improved by having all the mechanical advance in at a lower rpm. Some where in the low 2000's to 3000 rpm is going to be optimal but the only way to dial it in is on a dyno or with many runs down the 1/4 mile. Short of doing that some where around 2500 rpm is going to have you in the ball park.
