Shadow
Wanting to adjust valves on 340 with 273 rockers
on hydraulic lifters. Have read on other threads to get
the cam on the lowest point for selected
rocker ( that part is easy enough for me )
then rotate pushrod with fingers while tightening
adjuster until pushrod becomes a little stiff to turn. I now have 0 lash? This is where I need to make sure that this is correct.
Then I'm guessing that the adjusters (273 stock)
are either 16 or 18 threads per inch so to achieve .030
of preload I would tighten the adjuster another 1/2 turn?
Does all this sound correct or am I missing something?
