OK guys i need a little help and some advice. I currently have a 1974 7.25 rear dif in my 69 dart. I have an A-body 8.75 that i need to put in it. I have a few questions.
First, I need to use the same wheels that I have on the car currently and there is not much wiggle room side to side. (mayyyyybe 1/4") Judging by this chart attached, the two rear ends should be exactly the same width from flange to flange. Now I want to put disc brakes on the 8.75.
What are my brakes options? Will the disc brakes change the width from wheel mounting surface to wheel mounting surface?? I obviously rather not have the housing narrowed or lengthened. Plus then i can use stock length axles.
That leads to my next question, the 8.75 I have now has a 3.23 sure grip in it. Not sure the condition of it. Is there anything better I should up grade to? (locker, new sure grip, etc...)
And what axles should I go with?
Thanks guys!
Thanks guys!
