Going to install 340 stripes on my 73 first time any advice..
73Black340
Portland Maine
I got a couple days off coming and I an going to try to install the stripe kit on my 73 340..
So I know the car needs to be clean and free of wax etc.. I also know to load up a soap water mix on the car and stripe..
I dont know the exact measurements but I figure I will tape a picture to the window.
Any advice would be greatly appreciated...
dish washing soap! about 1 oz to a gallon of water. use a good spray bottle and spray the sticky side of the stripes. use a smal roller to push out bubbles. you will be able to reposition the stpipes easly. be carefull and take your time. it will turn out great!
Al
when you position your stripes get the back fender at the exact start point, any differance will run out inside the door and can be trimed. same with the front fender, position front of fender and run back to door and lose the excess inside the jam. you will do fine and it will look great.....
I chickened out and had my mopar buddy with loads of resto experience do em..
