OK, some pointers, hope they help. I assume you're going to use strictly for aluminum or do you also plan to do stainless(get separate liners if you can)? You need pure 100% argon, no other mix will work (with the possible exception of some helium mixes, let's not go there...) Black soot/smut is normal, moreso with 5356 filler. Try Maxal 4943, you'll probably prefer it, although it's new and hard to come by still, completely replaces both 4043 and 5356. You're going to find it much easier to use backing plates and/or welding spoons and run hot on anything remotely thin. On big items, use preheat. The issue with a spoolgun on aluminum is that you start cold and then the metal gets hot and you have to go faster and faster to avoid burning through, while you're stuck with fixed wire feed speed, so you have less fill. Getting the right settings will be frustrating, there's a pretty small sweet spot compared to steel MIG. And then the item heats up and the sweet spot goes away. All part of the game. Good luck. S/F....Ken M
