Good quality 1.5 roller rockers?
FWIW.... You cannot and should not be looking at the scrub patch width on the valve stem with 273 or stamped rockers like you would for roller rockers. They are 2 different animals. The contact point of the 273 and stamped rockers 'walks' across the valve stem tip in normal use; they are designed to do that. (It reduces the amount of wiping/scrubbing action between the rocker and valve stem for one thing.)
Believe it or not, that actually changes the rocker ratio through the lift cycle, and compensates for the rocker to valve angle changes to some degree... up to some level of lift. (It is actually better than a roller in that particular way.)
You can see from the OP's pix at mid-lift that the rocker is already slightly 'over-center' (i.e., a bit past being perfectly perpendicular to the valve stem axis). Lowering the shaft, or moving it way from the valve without raising the shaft center line, is ideally needed to get the scrub pattern more centered than it is. But both of those require some machining, I think. I personally would not mess with it at this time; there is still a fairly wide contact patch at the far end of the scrub patch, and since the spring pressures are not massive at full open, then I would think the contact pressures are still within reason. (One contact patch DOES seem to be at the limit!)
I'm glad you said it too. There always seems to be "som ting wong" when I say it.
:thumbsup: per triple R...
YellowRose, i appreciate your comments for sure. This is the pattern and also what they look like at half lift.
In my limited experience I didn’t think the geometry or contact patch was too bad given a stock set up and .100” more lift than they were designed for.
View attachment 1715362836 View attachment 1715362837
You need to send those pictures to Mike at B3 and see what he says. There is NO WAY, no POSSIBLE way that geometry is correct with that much lift.
I could be wrong, but I doubt it.
I understand that the pallet style rocker won't have a sweep pattern of a roller but that has to be damn near .300 wide. Or close to it.
I'll say it again, Chrysler guys need to spend more time with geometry. It's now relatively simple to correct. Your issue is going to be pushrod length.
It's worth a call to Mike and see what he says. That pattern is WAY too wide for my taste.
Again, if you change any part of the valve train, such as lift, or stem height etc. you need to correct for that. The stand height and placement was dictated by a lift of what? .450 lift? You've added a .100 to that.
It is logical that the walk across the valve stem would be more with such and increase of lift over the stock range as noted. (Hence the thought that shaft needs lowering.)
FWIW.... I've tested the 273 and stamped rockers for rocker ratio up to .500" when installed on a stock 675 head and watched the contact point walk across the valve stem. It moves quite a bit. Yes you are right.....I shoulda taken pix!
IMHO, part of why the OP's contact patch is moving out so far to the exhaust side is that his lift is going so far beyond the stock lifts for which these were designed. The range of the 'walk' has a lot to do with the curvature ground on the pad, and he is going well beyond what that was designed for. I don't necessarily think moving the shaft is going to change the contact patch/walk width. To reduce this, the pad would have to have the curvature of the pad changed. (Ground towards the outer edge with more curvature, I think.)
But the curvature of the pad also controls the degree of slippage that has to occur between the rocker pad and the valve tip, which effects the side force on the valve stem. (Which a roller tip gets rid of.) So it is a compromise, and I would bet the 273 rocker's curvature is set for lower lift AND limited slippage of the rocker on tip for durabilty of the stock valves and guides.
Redesigning that curvature AND then regrinding the curvature would be beyond a backyard mechanic's capabilities, and even most good shops. Something like the Crane rockers would probably have that pad curvature increased from what is on the 273 lifters, for better contact control at higher lifts, with the compromise of more slippage and side force.... which would be typically be thought of as an OK compromise in a modified engine.
Well, given that I am interested in valve train longevity, it appears to me that I'd better just order up a set of roller rockers and kit from Mike at B3 (whatever he recommends.) I don't know yet how quickly I could get a set, but will call him tomorrow and check on it. The next thing would be getting a set of pushrods. Hoping I can solve this rather quickly.
If you get the geometry kit you'll have to give Mike some measurements of the valve stem height to shafts. At least I had to. Then he'll work on your geo kit and send it out with your rockers. It didn't take him long to get them to me.
There's nothing wrong with your rockers. I've never seen a need to lower a shaft.
That's why you need to call Mike. He may tell you I'm off the reservation. It's not really a rocker issue.
Monday update:
1) FIRST, my apologies, as my rockers ARE spot faced correctly! I was sure the image in my head was correct when I wrote that they were not, ...but I checked today, and that part is good.
2) Mike at B3 called me back first thing this morning and we talked over options. He thinks that I'm fine staying with the 273 rockers for now as long as I can solve the adjusters staying tight. (He had checked in on this thread.) I will send him the info he needs to see what might be needed for possibly getting a set of 1.5 rollers in the future. Thanks, Mike!!!!
3) "Doc" at Automotive Machine and Performance (great Mopar oriented shop) here in Lawrence, KS thinks likely I'm just not getting the adjuster lock nuts torqued tight enough, and said that I likely need 30-35 lbs on them, which is more than I was doing. He handed me a set of ARP 12-point lock nuts which being taller give me an easier time getting a wrench on them. (The others were the low flat kind from Comp.)
4) And Gary at Rocker Arms Unlimited in Redding, CA is sending me two extra re-bushed and prepped replacement arms so I swap out the one or two with excessively loose adjuster threads.
So many great people, here on this forum, and other helpful and knowledgeable folks, all dedicated to keeping these old Mopars running. Just how cool is that?!!!! :thumbsup:
Monday update:
Well good. I was gonna say ask Mike his opinion of which rocker to run, but it sounds like you got it handled for now at least. Maybe you won't need to buy more rockers after all.
Monday update:
Mike didn't think that sweep was too wide?
As I understand it, he also talked about the way the non-roller stock adjustable arms "walk" across the valve as designed, with some slip at the ends of the walk, and since I am putting a bunch more lift to them there will be a bit more at both ends of the travel. But basically they are doing what they were designed to do. with the curve of the pad, they kinda roll across the surface. It's nothing like what happens with a roller.
Well then I was wrong. That's why you call Mike. Then you know it's right.
Try some lash caps and check the sweep
if stock was for 450 lift and you go to 550 but all the extra lift is down from the stock 450 lift location
raising the valve tip .050 would give you up .050 and then the additional 100down would put the tip down an extra .050 instead of .100 should put the geometry back to stock (of course different length valves or sunk seats make imperfect science)
so see if a lash cap makes problem better or worse- might tell you which way to go
BTW YR doing the mid lift gives you equal up and down angles which gives you the narrowest scribe which is what OP needs to achieve
most of my experience was with long valves and aluminum stands but I can see that moving the shaft down with stock/ 273 rockers would give same effect as a lash cap
way different than roller rockers where anything less than up and back just gives funny results (bad things happen)
