Limited the travel of front suspension. Took some preload out. Raised the wheelie bars to 7". Shift 1-2 @ 6600 and 2-3 @ 6800. Went 9.43 @ 139 in the qtAwesome, make any changes? What’s the shift points now? What timing are you at on alky?
Nice pass, are you at 34 degrees total timing? Same on gas and alkyLimited the travel of front suspension. Took some preload out. Raised the wheelie bars to 7". Shift 1-2 @ 6600 and 2-3 @ 6800. Went 9.43 @ 139 in the qt
Yes. Still haven't worked on the jets or timing. It's still leaving with the lf higher than the rf. Still have some work to doNice pass, are you at 34 degrees total timing? Same on gas and alky
Beautiful
