What a great project. Heck build a hot rod out of it and steal Chuck's truck from him to tow boats and cars with. :-\"
Agreed! I don't really want to change it. It needs some pounding out and there's a few cracks in the fenders that need repaired. Check out the old gas weld on the l/r fender! Nice work done at the ranch! Probably used bail wire for rod! Almost want to do the same on the others and keep it period. Again, fun decisions!that patina on turqouise is amazing.
Lol the motor and tranny from my truck is probably going in it! I swapped my 360/4 speed for the 350 to put in the suburban.
So what are you going to put in your truck?
I haven't talk myself out of that idea either! Two wheel drive stump puller!.. and no! I will not make it 4wd Chuck! :wack:
Larry
It's gonna be a 3/4 ton trailer. To put behind the suburban. I'm tired of getting stuck on the dirt roads when it rains, so I got the $500 4x4 suburban. Larry had the 72 vette motor in his garage and needed a Mopar sb and I needed a sbc. So I'll drive the burban until I can get my cummins.
Whats wrong with 4x4s
Cool so does that mean me and Asa can change your name? :-\"
all pre 56 mopars were positive earth (ground)
Not a thing. I've always owned one or two and any given time. My daily driver is a 08' Nissan Frontier 4x4 which has been a great truck for us. At one point I was making a 4x4 out of a J2000 and a Jeep Cherokee. It got sold for someone else to finish. I want to keep this 2wd. The more I think about it, keeping it relatively stock appearing with the patina and going for the sleeper thing is sounding like the path I may take. Still not sure if I will stick with the semi-hemi or not. The sound of an old low deck hemi like the one Rob has certainly appeals to me as well. But the dollars and cents of a LA engine swap may be the route. Decisions, decisions!Whats wrong with 4x4s
Did you loose any eyebrows?:glasses7: LOL! I still need to pull the starter and inspect it.The trucks were Negative Ground, like a newer vehicle.
Try to hook one up as a Positive Ground (if it still has the wipers, generator, and other accessories hooked up) and it'll throw fire. I know, I tried it by accident once on my '48 ops:
63 Morepar, check out Roberts Motor Parts for parts for your truck, they sell all kinds of parts for the antique mopar cars and trucks. Everything from Upholstery to Suspension components (That includes Glass, Internal Engine Parts, etc).
When I bought a shackle for my '48, I also got a nice catalog from them that was the size of a phonebook.
