JGC403
This is my first car with an 833. So I am learning as I go along. Transmission is a cast iron case and tail 833 OD.
It grinds when shifting into 3rd, so needs synchros.
Now another problem:
When the clutch is disengaged, it doesn't make any noise, (and it seems like it disengages all the way at the end of the clutch pedals travel). Or when the clutch is engaged and in neutral and stopped. When clutch is engaged and the car coasting it sounds like rocks are inside the transmission. Also when it is in gear 1st, 2nd or 3rd it makes the same noise. But in OD no noise. 3rd gear is the worst, at one point 1st and 2nd didn't make any noise. So it is really inconsistent. HELP.
I'm just trying to come up with ideas. Since its a cast iron case OD, parts were swapped around. What would happen if a smaller bearing retainer was used than the hole in the bell housing?
