tom340
This is an old issue not resolved.. (gauge works, sender unit Ok, good ground from sender to chassis) Real quick the problem is the fuel gauge works just fine until the motor is started. Then I LOSE power TO the back of the fuel gauge. Its a '70 rallye dash, fuel, oil press and temp off same power.
<Another Duster owner just told me he had similar problem and asked me "is your engine grounded?" I've never really noticed a Duster, Dart or Demon engine ground harness. His gauges were all wacked after the motor re-installed from an engine rebuild. He was at a loss for what had happened and his mechanic either attached or "re-attached" a ground strap from the heater box bolt to an exhaust stud bolt and he said the gauges worked fine again.
< I want to stay clear of wondering if the sender unit is bad (not) or the sender is not grounded (it is-and tested) or if the gauge is bad (also tested-not the problem) My question is does anyone else have a ground strap from the chassis to the motor????????????? Does anyone know for sure if they came grounded from the factory, and if so where did this ground connect from/to? Im hoping its just this simple! Thanks for any feedback
One last thing, I have a black ground wire that for some reason is attached from the wiper motor to a heater core bolt. Not sure of the purpose, or if its even right..
