You need battery to block (or head) and battery to chassis which is your two wire negative battery cable...and also a block (or head) to chassis or firewall. I run mine on the passenger side back of the head to the firewall. I also run one from the voltage regulator on the firewall to the head for good measure...I'd say you dont need 2 straps going from each head to the frame...or atleast you shouldnt.
