Guages intermittent issues need Help
Canada
Hi Gang, In my 70 swinger I have a Ralley dash, the one guage that has the Fuel, Oil Pressure and temperature has electrical issues.
For some reason, always on startup cold it always works, within 10 to 15 minutes, they all shut off. I have gone in behind to check connections and all are very clean with good power and ground.
I checked the capasitor and it works fine, even changed the capasitor and same thing, any ideas ?
The mechanical limiter that supplies power to those 3 gauges is housed inside you rally fuel gauge. You can go to the DeMonIVR link below and read all about it or just google gauge voltage limiter. Hope this helps
Thank You so much Red fish, this is extremely helpfull, I have been trying to figure this out for a week now and tried just about everything, I will give that a try.
