Halp! Reassembling a holley 650CFM
Chained_360
Delusional Member
Indianapolis, IN
So I'm putting my old holley 650 single pumper back together, and I'm stuck on reassembling the secondary bowl onto the carburetor body. The issue is that I cannot remember the order in which the two metal plates and single gasket go back on. In order, starting with the first component to contact the body and then outwards (body to bowl), whats the correct order of parts? Is it bronze plate, gasket, zinc plate?
Found a picture, Gasket, metal plate, gasket, metering block
