Also, initial timing is way low. Should be up around 18-20 with the total limited to 34-36.
Rob.. the motor is plain jane stock from what i know about it with the exception of the intake, carb, and headers.
If I block off the vacuum advance and set timing for idle at 12° , when I plug the advance line back in and read the total, the timing is over 40 at 2700-3000.
Am I missing something...???
