try vinegar-may take some rubbing- try soaking a paper towel to leave on it. it is a mild acid- the hard water should be a base..... cheap and won't damage anything- flush with water
I don't know whether it will work, or not. Look into a product called CLR, which stands for Calcium, Lime, and Rust remover. As I said. I don't know whether or not it will harm the aluminum.
Is it polished? if so you might try california deoxidizer(a mild acid), followed by california polish, this stuff is from just across the river from me, but I guess no one would buy Nebraska polish.
